 Date/Time is Tue May 21, 2013 8:59 am
Import M4V to FCP, how to convert M4V to FCP on Mac?
Post new topic Reply to topic Computers OverClocked Forums - ComputersOC Distributed Computing Teams All times are GMT - 5 Hours - EDT
tomia
PostPost subject: Import M4V to FCP, how to convert M4V to FCP on Mac?
Posted: Thu Aug 02, 2012 8:43 am
FCP (Final Cut Pro) is a non-linear video editing software that allows Mac users to edit and make their videos and movies for sharing on Mac. M4V is a standard file format which based on the MPEG-4 Part 2 compression. Want to edit M4V files with FCP on Mac? You can make your own personlized and unique videos by using FCP on Mac. When you try to import M4V files to FCP, something happened. You can't import these M4V files to FCP successfully. However, Mac M4V to FCP Converter offers a perfect solution for Mac users.
Mac M4V to FCP Converter as the best program for Mac users to convert M4V to FCP supported video formats like MP4, MOV, DV, HDV, etc on Mac. In the other hand, this converter also enables users to convert M4V to other video formats like MKV, FLV, AVI, WMV, MPG, 3GP, etc on Mac. It features working efficiently and high compatibility, and high quality outputs. Moreover, many multimedia device such as iPad, iPod, iPhone, Apple TV, PSP, PS3, HTC, Xbox 360, etc are also supported.
The M4V to FCP Converter for Mac gives your more surprises. You can set some settings to adjust the videos. Cropping, merging, trimming videos, adding watermark, and so on are available for you. According these settings, you can get the target files as your will. After converting M4V to FCP Mac, just import converted M4V to FCP for further editing on Mac.
The tutorial for you to convert M4V to FCP on Mac
Step 1. Add M4V files to this program
Free Downlaod and run this Mac M4V to FCP Converter. Click "Add" button to load the M4V videos to this converter on your Mac.
Step 2. Select the output format
After adding M4V videos, you can click the "Format" bar to choose the ".mp4" as the output format, then set the destination by clicking "Browse" button.
Step 3. Start converting M4V to FCP on Mac
All the settings finished, click "Convert" button to convert M4V to FCP on Mac. After cnoversion, you can click "Open" to find the converted files.
Post new topic Reply to topic Computers OverClocked Forums - ComputersOC Distributed Computing Teams Page 1 of 1
No new posts How to import Panasonic SD900 AVCHD V... daisy520 Broadband Tweaks, Tips and Optimization 0 Mon May 20, 2013 6:18 am View latest post
No new posts How to import Sony PMW-500 media to F... lydia622520 Broadband Tweaks, Tips and Optimization 0 Fri May 10, 2013 10:36 pm View latest post
No new posts How can I import SWF video to Premier... lucasjacbo The General Store 1 Thu May 09, 2013 10:18 pm View latest post
No new posts The Correct and Simple Way to Import ... cindyhuan Over Clocking and Mods 0 Sat May 04, 2013 3:09 am View latest post
No new posts How to Convert XAVC to FCP 6/7 for Ed... cindyhuan Over Clocking and Mods 0 Thu Apr 25, 2013 4:00 am View latest post
