 Date/Time is Thu Jan 17, 2019 3:34 pm
December $1200 Montly Rig
PCracer51
PostPost subject: December $1200 Montly Rig
Posted: Sun Dec 02, 2007 3:49 pm
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
MSI P6N SLI-FI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130082
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
XFX PVT88PYDE4 GeForce 8800GT Extreme 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150253
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136012
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
2x SAMSUNG 20X DVD±R DVD Burner Black PATA Model SH-S202G - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151151
NZXT Alpha Black Steel ATX Mid Tower Computer Case with Open Window - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146041
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
Subtotal = $1272
MIRs
PSU $35
RAM $40
Mobo $20
Total = $1177
http://valid.x86-secret.com/show_oc?id=91038
perdooky
PostPost subject: Re: December $1200 Montly Rig
Posted: Sun Dec 02, 2007 3:58 pm
Why not the intel core 2 quad? If you could would you use the quad from last wishlist on this system? ( http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017 ) Also, what mobo with the quad since you probably would need another. (I'm looking to build a quad system)
PCracer51
Posted: Sun Dec 02, 2007 7:25 pm
I've done a lot of the previous ones as quad systems, just changing things up. That board above will run a core 2 quad fine, as the core 2 extereme at the time of the board's launch was the QX6700, the same as the current Q6700.
a2love
Posted: Mon Dec 10, 2007 3:37 pm
Just wondering, if you had abit more to spend would there be another Motherboard you would look at?
I'm building a Q6600 system and am scratching my head about motherboard choice. I'm planning to purchase the G92 8800 GTS and may go SLI in the future. I don't want to limit my future chip expansions, but i'm also weary of X38.
Aslo, do you think it is a big concern that this board goes 8x on the one PCI-e slot when in SLI?
Other than that, I really like you're component choices and will most likely make this the start point of my build. Thanks Smile
PCracer51
Posted: Tue Dec 11, 2007 4:57 pm
The P6N is a really good well rounded board, and it has gotten a lot of good reviews from the tech community. The higher version of this, the Diamond series has a few more features. Otherwise, the EVGA 650i and 680i boards like the A1 and the T1 are good, the Asus 975X boards, and nforce 6 boards.
The X38 is overkill for a build right now, for the price, it's not worth the added features. The lack of SLI is another bad point for that board. I can't comment on the 8x drop on the second PCIE slot, I haven't been using a rig with SLI that much.
Adrego
Posted: Wed Dec 12, 2007 8:03 am
Personally I would have gone for an E6750 Wink
PCracer51
Posted: Fri Dec 14, 2007 12:44 am
I think newegg was out of stock at the specific time I built this rig, but yes, it is a cheaper and better chip. It would be a wise change.
OberCanober
Posted: Fri Dec 14, 2007 9:45 am
I've noticed lot of stuff out of Stock. People must actually be buying their kids or friends $300 video cards or Christmas or else NewEgg is trying to reduce its stock of parts to show more income for the end of the year.
Either way the 8800GTS 320MB are all out of stock as well.
No new posts Drop Jordan to Come Back in Stores th... tomrichard618 Build a Computer - Computer Building Help 0 Tue Nov 28, 2017 3:58 am View latest post
No new posts Adidas NMD r1 black out heel December... Virgo2017 Build a Computer - Computer Building Help 0 Thu Oct 12, 2017 12:03 am View latest post
No new posts Choi Hongman formed a duo Singer debu... dvdsjpdvd Build a Computer - Computer Building Help 0 Wed Jan 04, 2017 11:08 pm View latest post
No new posts Seahawks posted a 4-0 record in Decem... miaowang123 Over Clocking and Mods 0 Wed Oct 26, 2016 2:50 am View latest post
No new posts had seen her on 17 December the night tangtang520 Broadband Tweaks, Tips and Optimization 0 Thu Sep 29, 2016 2:03 am View latest post
